Vray 3.6.05: "Auto guess vertical tilt" does not work with DR
  • Vray 3.6.05: "Auto guess vertical tilt" does not work with DR
    Hello everybody,
    the "auto guess vert. tilt" function with vray physical cameras does not work with distributed rendering. Only my main workstation renders the tilt correction correctly, the nodes ignore the auto setting.
    Is there a way to fix this? (Or will I have to build around it and manually animate the tilt during the animations?)
    Max 2018(5) on all machines
    Vray 3.6.05 on all machines
    I know, this may be no direct solution to you problem, but what happens if you render with Backburner. At least it could be a workarround until the problem is solved.
    Workstation: Ryzen 9 5950x @ 4,20GHz 64 GB RAM, NVIDIA RTX 4090, Win10 Prof.<br>Rendernode: AMD Threadripper 2990wx 64 GB RAM, Nvidia Quadro P5000,Win 10 Prof. MAX 2025.2, VRay 6.2, ForestPack, RailClone, RichDirt, KStudio ProjectManager....
      Hello there,
      thanks for the tip, but this won´t work for me. With backburner, every node takes around 2-3 minutes until it even starts rendering a new frame (file size is 3 GB) while with DR, the setup procedure only needs to be done once and then the animation continues with "pure" rendertime. I will then make manual keyframes for the tilt correction, which is a bit of a pain due to the length, but it´s doable.
      Shame it´s a bug, that feature was much appreciated.
        Hello!
        This issue is actually fixed in V-Ray Next.
        Thank you for reporting!
        (Manually animating the tilt parameter should work in V-Ray 3.6 if you use V-Ray DR Spawner; but it will not work if you use DR with V-Ray Standalone due to export issue that is fixed in Next.)
        Margarita
        Margarita Stoeva | chaos.com
        Chaos QA (V-Ray for 3ds Max)
