Hi guys!
I am a pretty new user to vray, so I apologize if this is something pretty obvious to solve, but haven't found a solution yet online or at least am not searching for the right terms.
I am trying to render an animation sequence using .vrimg files, but every time I go to set the sequence to render (whether it's a range or the whole timeline), vray will render the appropriate frames, but it saves one frame over the other and does not save each individual frame with its frame number. So essentially rendering a 1000 frame animation only outputs one saved frame at the end, because each new frame overwrites the previously rendered frame.
If I change the file type to say a .png, the files render properly and with frame numbers at the end.
Is there something else I need to change in the settings in order to render a sequence of .vrimg files? I am trying to use the vray denoiser as my ultimate goal for the animation. Thanks for any help!
