Normal Maps Do Not Show Correctly
  • #16
    Originally posted by theedge View Post
    This generally happens when you don't have a UVW Map modifier applied to your object. Is this the case in your test ?.
    This is the strangest solution to this problem. I have no idea why it is like that, but it needs to be fixed!
    • #17
      Now I don't know if this is a bug or an expected behaviour.
      LOL this is very strange and un expected behavior ! thanks for sharing and yes I'm sure this is a bug that's need to be fixed !
      Simply, I love to put pixels together! Sounds easy right : ))
      Sketchbook-1 /Sketchbook-2 / Behance / Facebook
      • #18
        How could they not have noticed this issue, maybe they did and it will be fixed in the 4.2 version that's coming out. Should be news on that since this is the first day of Total Chaos.
        • #19
          I downloaded that test scene and it seems you can also collapse the Box to an Editable Poly or apply a Turbosmooth set to 0 iterations to fix the issue too.
          David Weaver
          Senior "Belief Crafter"
          Realtime UK
          https://www.artstation.com/artist/weaver
          • #20
            3DsMax Box auto-generated mapping coords are weird, somehow front and back faces are connected. Guess it's safer not to use them.
            • #21
              Thank you for the provided scene. It seems there are differences when rendering an object with and without using a UVW modifier. I have forwarded the issue to our developers for further investigation.
