Normal Maps Do Not Show Correctly
  • Normal Maps Do Not Show Correctly
    We have been trying out Vray Next vs Corona and Vray has issues with normal maps. We bring in the normal maps with gamma 1 and flip green, but it doesn't show correctly with Vray CPU, but it Does with Vray GPU.
Name:	Vray Adv vs RT Gamma 1 Normal Map.jpg
    We are aware of the differences, however, our goal isn't a 1:1 render result as the CPU.
    Quoting Blago:
    "These are different engines - not meant to be pixel to pixel the same. They use different algorithms and approaches to thing like light sampling, bump mapping, etc. If you want to use V-Ray GPU, start with it from the start and there will be no surprises."
      Quoting Blago:
      I understand that there will never be a total parity between the two renderers.
      However, the result shown by the CPU version is plainly wrong. It's totally missing the lighting direction from the left. Also, the version of CPU is much less detailed. It is not a good result at all. It would be best if you guys could check the scene, there is something seriously off.
        By all means, send the scene to support@chaosgroup.com so we can take a closer look.
          I would love to take a look at this file too.I have few ideas that I would like to check.
          Simply, I love to put pixels together! Sounds easy right : ))
          Sketchbook-1 /Sketchbook-2 / Behance / Facebook
            Okay I'll pack the scene, but honestly you can do it with any normal maps
              Here is the scene.
              https://drive.google.com/file/d/15vd...ew?usp=sharing
                I couldn't download the file because of the slow internet that I have here, so I did quick test with another map and found that using Max Normal Map (show incompatible maps to see it ) instead of using VrayNomral map give almost identical result to Vray Next GPU result.so there is definitely something wrong with Vray normal map ..I don't usually use normal maps but I remember facing a problem years back with VrayNormal map and switching to Max Normal map solved it(there were and topic here in the forum about it ) ,so I'm not sure if it is new bug or VrayNormal map has always been like this .
                  Every object in my scene renders different and wrong in ADV vs correct in RT because of the Normal maps. I'll have to try bump mapping also and see if that's an issue too.
                    You are absolutely correct that Max Normal Map renders normals correct like RT in Vray ADV. But Vray using IPR doesn't render Max Normal Map Correctly.
                      When I was testing the tips from Vlado I was struggling to get the right look and it wasn't the way he described it to be.
                      https://forums.chaosgroup.com/forum/...s-gamma-or-not
                      A.
                      www.digitaltwins.be
                        I've noticed this too on tiled materials such as brick. There is no definition to the vertical grout lines.
                        A quick test of my own in CPU.
                        Max Normal. Bump 100. Multiplier 4.0. Flip green Click image for larger version  Name:	Normal_Max.jpg Views:	1 Size:	485.9 KB ID:	1036079
                        Clear definition between the brick and grout IMO. Good micro shadows.
                        Vray Normal. Bump 100. Multiplier 4.0. Flip green Click image for larger version  Name:	Normal_Vray.jpg Views:	1 Size:	478.2 KB ID:	1036080
                        You read the horizontals more than you do the verticals, especially evident on the side that is in shadow. Less micro shadows too.
                          This generally happens when you don't have a UVW Map modifier applied to your object. Is this the case in your test ?
                          See my example :
                          Now I don't know if this is a bug or an expected behaviour.
                          mekene
                            In this example no I didn't! Applying one resolved the issue. Many thanks!
                            • #15
                              Originally posted by Donfarese View Post
                              I can't help with the GPU/CPU discrepancy. But to get a correct render with CPU try the suggestion I made to DanSHP : apply a UVW Map modifier to the box.
                              mekene
