MultiTile UDIM & VrayHDRI for vrscene
  • MultiTile UDIM & VrayHDRI for vrscene
    Hello,
    I'm trying to render a fully textured character (with substance painter) for testing the limits of the vrscene exporter.
    Looks like we have a limitation with the multiTile map operator.
    Here's how we use it :
    We'd like to use VrayHDRI instead of bitmap to import texture. ( for tiledEXR)
    We also use MultiTile in custom mode (because in UDIM mode, with <UDIM> tag in filename, the render works but the asset tracking lost the file, so it's a real mess when talking to real production & network render)
    Here it's not suppose to work, but i does The local render (and network on local renderfarm) is fine.
    But when i'm trying to export a vrscene (or a preview in the submit to vray cloud) and i lost all of my maps (udims everywhere)
    Do you have any recommended workflow for massive UDIM charracters usable in vrscene ?
    Thanks !
    http://tatprod.com/
    Hello,
    i've made a simple scene to try to find where is the problème.
    UDIM_MultiTile_vray.zip (3dsmax 2019)
    And it looks like it's the custom fil pattern that is not supported by vray
    http://tatprod.com/
      Yes, and there is warning about this in both - the log and the Cloud submitter.
      Peter Matanov
      Chaos
        Yes, but is there's a hope that this will be supported one day ? or should i search for a workaround
        http://tatprod.com/
          Maybe, but that won't be anytime soon.
          Peter Matanov
          Chaos
            For the moment the best way to do UDIM textures is through VRayHDRI with the <UDIM> tag.
              Try 3dsMax 2020 OSL bitmap lookup.
