vray particle tex broken in max 2019 / vray next 1.1 (4.10.02.0001)
  • vray particle tex broken in max 2019 / vray next 1.1 (4.10.02.0001)
    i went to use it to make a wetmap shader and it doesnt come up with the UI anymore to enable you to pick the particle system.
    tried on a few different scenes on a few different machines. i normally use it in a blend but same issue if you try load it in a normal material slot.
    any ideas how to get around this? is this fixed in newer builds?
    Hello,
    Do you mean this one:
    It never had any parameters in it ?
    Yavor
    Yavor Rubenov
    V-Ray for 3ds Max developer
