Crashes when using IPR and toggling isolate object
  • Crashes when using IPR and toggling isolate object
    Hi all,
    Getting fairly frequent crashes when using IPR and exiting isolation mode. I use isolate a lot in my workflow.
    Screenshot of error attached. Can try to provide scene (NDA), but please can I have an email address to send it to?
    3DS Max 2017
    VRay Next update 2
    Thanks,
    Max
    Freelance 3D Generalist
    www.maxwood.co.uk
    Hello,
    You can send it over to philip.shounev@chaosgroup.com
    Philip
    Philip Shounev
    QA department
    Chaos
    philip.shounev@chaos.com
      Originally posted by Philip Shounev View Post
      Hello,
      Philip
      I've sent that over now, thanks Philip.
      www.maxwood.co.uk
        I've had a look at the scene but still couldn't reproduce the above mentioned crash. Are there any specific steps which need to be executed, any specific object to be moved or it happens non-deterministically? Also, would it be possible to provide a vraylog and a .dmp file (both located in %temp% directory) ?
        Best,
        Philip
        Philip Shounev
        QA department
        Chaos
          Best,
          Philip
          Hey Philip,
          Thanks for taking a look. I can reproduce on my end by starting IPR mode, double clicking "CTRL_BARREL_COG" to select it and all the linked objects, entering isolation mode, and then exiting isolation mode.
          I will email over the files you requested
          Cheers,
          Max
          www.maxwood.co.uk
            Hi again,
            Thank you for providing the requested files. I've forwarded the issue to our dev team and it has been logged in our bug tracker under VMAX-8885.
            Best,
            Philip
            Philip Shounev
            QA department
            Chaos
              Hello Philip, did this issue get resolved?
              I'm using next - update 2 and this still occurs
              thank you
                Might have to update Forest Pack. Sorry to bother you all
                  Hello,
                  As a workaround for isolating objects, I would recommend using debug shading IPR (isolate selected mode) functionality, which would provide more flexibility.
                  Best,
                  Philip
                  Philip Shounev
                  QA department
                  Chaos
