Unwanted double reflections in Max2019.
  • Unwanted double reflections in Max2019.
    Hi.
    I'm experiencing something odd when I have a glossy surface and use vray-lights as reflections. If I place two vray-lights, one a little behind the other and moved to one side, the reflection in 2017 looks as I would like it. In Max 2019 however, it looks like the lights are transparent, giving me an unwanted, double, reflection. How can I prevent this from happening in 2019?
    Any thoughts on this matanov?
    All the best,
    Rasmus, Phiro, Denmark
    Could you send this scene to support@chaosgroup.com along with information about your V-Ray, 3ds and Windows versions, so we can take a look? Mention this thread as well.
      Hi Aleksandar.
      I have sent the file. The problem occours when the small light is set to "Invisible" - then the reflection becomes transparent. If the small light is visible, the reflection looks good, but then I can see the small light in the rendering, and not only in the reflection, which I need. Works fine in 2017.
      /Rasmus
        Thank you for the report and provided scene. We've made a note about this for our developers to look into and further investigate.
