Urgent
Max 2020.1
VRay 3.70.1
I am trying to do some animations and I have a lot of problems. I am using the IR prepass + LC method.
The first problem was that the animation started at frame -5 ... whenever I put in camrea path (IR or LC) everything went black ... after seeing here a post with a similar problem (VMAX-8901) I put the animation starting at 0 and already doing the IR and LC. But only works if Time Output is in single frame Active Time Segment ... In Range and Frames, Max always crash .. Max 2020.1 VRay 3.70.1. I also tested it on Max 2019 and always crash ... Having to do a lot of animation just with Active Time Segment is almost impossible.
