Next 2 and Next 1 render different
  • Next 2 and Next 1 render different
    I have an old scene which Next 2 renders much brighter than Next 1. And I tested with Vray 3.6, the result is same to Vray Next 1.
    Attachment is the scene.
    Run the commands to reproduce:
    > YourVray4.1Path/bin/vray.exe -sceneFile=e1.vrscene -imgFile=4.1.jpg
    > YourVray4.2Path/bin/vray.exe -sceneFile=e1.vrscene -imgFile=4.2.jpg
      Is it an know issue? It cloud be reproduced easily.
        https://forums.chaosgroup.com/forum/...52#post1035052
        Lele
        emanuele.lecchi@chaos.com
        Disclaimer:
          It might be something else, please send me the max scene.
          Peter Matanov
          Chaos
            Hi,Lele,
            I've read the thread.
            The thead was talked between 2018-10 and 2019-05. So the thread was comparing Next/Next1 with 3.6.
            Accoring to Next release time:
            - Next was on 2018-9
            - Next 1 was on 2018-11
            - Next 2 was on 2019-6
            The core problem for me is Next2 renders more brighter than Next1. Is this a known issue in Next 1?
              Hi, slizer,
              The scene is here : https://forums.chaosgroup.com/filedata/fetch?id=1048537
                Can you please share the Max scene?
                Peter Matanov
                Chaos
                  Originally posted by 18322119@qq.com View Post
                  Hi,Lele,
                  Duh me, sorry.
                  Glad Peter sorted it.
                  Lele
                  Disclaimer:
                    Thanks for the provided files and information. This is a known issue - there is a difference in the GI between visible and invisible Mesh Lights. Our developers are already informed about the matter. As a workaround and to match the results, set the invisible value of your mesh lights to 0.
                      Thank you Aleksandar. The workaround works.
