error: UNHANDLED EXCEPTION: Rendering frame
  • error: UNHANDLED EXCEPTION: Rendering frame
    hi,
    Suddenly, Everytime I send a render thru backburner, I´m having this error:
    Last marker is at D:\cgrepo\vray\vray\src\vrayrenderer.cpp, line 4208: Preparing global light manager
    It happens at the end of the rendering. I´m using denoiser and glare.
    I´m attaching vraylog.txt
    Surrealismo
    https://www.facebook.com/surrrealismo
    Hello,
    First of all - when the error happens Max should create a crash dump called 3dsmax_minidump.dmp in your temp folder - could you attach it here or send it ?
    Additionally could you try the same scene without denoiser and glare - from the log it seems the error happens while denoising but the test will show for sure.
    Yavor
    Yavor Rubenov
    V-Ray for 3ds Max developer
      I looked on the slave and did not find that file. Could you explain me where to find it?
      I did the test without glare and denoiser and it rendered fine.
      Surrealismo
        It should be located in the temp folder - you can open it if you type %temp% in the address bar of Windows Explorer.
        Looking at the log it seems the denoiser is trying to use hardware accelerated denoising with some nVidia graphics card - maybe there is some problem with it and it crashes. You could try to disable the "Hardware acceleration" option in the Advanced denoiser parameters and see if it works.
        Yavor Rubenov
          I find that file on my local computer... but I cant find on the slave computer.
          I´m going to test with hardware acceleration disabled.
          thank you!
          Surrealismo
