Vray NEXT update 3.1 problem
  • Vray NEXT update 3.1 problem
    Just try Vray NEXT update 3.1, and i facing this issue, please help.
    Jackie Teh
    3ds Max 2023, V-Ray 7 Hotfix 2 [7.00.08 build 00000]
    AMD Ryzen 9 7950X 16-Core Processor@4.50 GHz | 64GB RAM | Nvidia RTX 4090
    Website: https://www.sporadicstudio.com
    Email: info@sporadicstudio.com
    YouTube: https://www.youtube.com/c/SporadicStudio
    Just found out, this happens every time I increase the min shading rate
    Jackie Teh
      Could you send the scene to support@chaosgroup.com so we can take a look? Mention this thread in the e-mail as well.
        Try turning off adaptive in your dome light.
        Bobby Parker
        www.bobby-parker.com
        e-mail: info@bobby-parker.com
        phone: 2188206812
        My current hardware setup:
        • Ryzen 9 5900x CPU
        • 128gb Vengeance RGB Pro RAM
        • NVIDIA GeForce RTX 4090 X2
        • ​Windows 11 Pro
          Email send
          Jackie Teh
            Yes, already try that, it solves the problem, but render time increase a lot
            Jackie Teh
              Yep, it will. It was a NEXT feature that never worked for me.
              Bobby Parker
              phone: 2188206812
              • Ryzen 9 5900x CPU
              • ​Windows 11 Pro
                There is a further workaround: make sure you have the shading properties of all geo to their default: turn back on visibilities to GI and camera, shadow casting and everything else (for the main window glass pane, especially.).
                You'll get the artifacts to disappear, and the rendertime shouldn't grow by as much as it would with adaptive dome off (on top of providing for a more accurate render.).
                Mileage may vary, however, so test it out before committing.
                Lele
                emanuele.lecchi@chaos.com
                Disclaimer:
                  after few hour tests, I can confirm the problem caused by adaptive dome turn on. here some print screen, all setting is same except turn on and off adaptive dome. render time difference around 3 minutes. ( i have check all the setting you have mention above)
                  ps: min shading rate is set 32, sample is 1-24
                  Jackie Teh
                    nice one.
                    Yeah, the broken one isn't sampling right, for whatever reason.
                    Lele
                    Disclaimer:
                      nice one.
                      Any new update on this issue?
                      Jackie Teh
                        Thanks for the provided scene. We are aware of the issue, it is linked to the minimum shading rate and adaptive dome as suggested. To eliminate the artifacts, lower the minimum shading rate.
                        Viktoria Dimitrova | chaos.com
                        Team Lead, Cosmos Asset Creation
                          Thank you for your reply
                          Jackie Teh
                            To save yourself further pains, should you not be the original author of the scene (i.e. you inherited it), you could reset the settings to their default by the usual method of swapping to another renderer and back to V-Ray.
                            Notice you'd lose any color mapping and/or environment maps, this way, so be wary of that.
                            Lele
                            Disclaimer:
                            • #15
                              Thanks for your reply.
                              I always do that to reset everything to default even when I open an old scene with older Vray version.
                              For this scene, yes, I am the author of the scene.
                              Jackie Teh
