VRayDenoiser for Nuke Feedback
  • VRayDenoiser for Nuke Feedback
    This is a short feedback from experimenting VRayDenoiser plugin for Nuke.
    VrayDenoiser 1.7 for Nuke 11.3v1 revision 577b6d56
    Nuke 11.3v6
    Pros:
    + It is the only AOV controlled Denoiser ! (as we know)
    + Best AOV controls are Albedo (Diffuse Filter) and Normals. (are negative WorldNormals taken into account ?)
    + Best results are with RAW light.
    Cons:
    - World Position doesn't have any impact, as we can see (and it's the bigger useless AOV, as 32bits !)
    - Denoise can only work on a single AOV at the time, forcing us to shuffle our EXR.
    - Noise Threshold doesn't reach very high noise amount, leaving us with heavy fireflies.
    - TEMPORAL causes Crashes. This our hardest bug to face.
    - TEMPORAL causes unwanted AOVs Time offset.
    - TEMPORAL causes undesired cropping because of Bounding Box variation in time
    (if nearest frames have shorter BBox, the Denoised result is cropped)
    - TEMPORAL changing frame range causes result to be black until nuke script is closed and re-open.
    - when knob values changed, result doesn't display until changes are made in the Channels tab.
    - Denoise is computed event when not part of the displayed stream.
    We are experiencing to use it in production, do you planned to work on this tool ?
    Thanks !
    -p-
    http://tatprod.com/
    Up !
    is this tool deprecated ?
    http://tatprod.com/
