Transparent Objects
  • Transparent Objects
    Hey guys,
    So to explain my issue in a simple way, I have 2 objects, 1 is visible from frames 1-100, and the other from 90-200, basically when because transparent while the other shows up, kind of faking a fade effect here.
    If I am to use the standard 3d max materials and animate the opacity of the material, and render, it works perfect, but when i use vray materials and animate the refraction to max, and the reflection to 0, to make the objects disappear, it also works but when i render it picks it up in the alpha channel + any other render elements such as the AO.
    Any idea how I should approach this, or if animating the refraction is the right way to do this?
    Thanks guys!
    Hi mossawi
    Why not animate the opacity ? Or the visibility parameter ?
    mekene
      Originally posted by theedge View Post
      Hi mossawi
      Would you do that just through the opacity map? which is the visibility parameter?
        The visibility parameter is in the object properties dialog :
        mekene
          Thanks man .. didnt know that could be animated
          Im using your first suggestion of animating the opacity map and works great, thanks a lot!
            visibility does work but for some reason it is very very slow to render done this way.
            WerT
            www.dvstudios.com.au
              Ah is it so. Maybe the visibility setting is not properly supported by V-Ray ? Someone more knowledgeable could answer that...
              I personally don't render these effects. If an object is going to fade or be transparent I'll render it separately so I have full control over the effect in post. Quicker and no need to render again with each tweak. Is this doable with your project ?
              mekene
                Visibility sucks. Try this method which works mostly just fine
                https://forums.chaosgroup.com/forum/...illity-channel
