3ds Frame Buffer RAM consumption
  • 3ds Frame Buffer RAM consumption
    Hello,
    in the Vray doc there's a line concerning the RAM consumption of the 3DS Frame Buffer
    Even though you select the V-Ray VFB as your output, the 3ds Max VFB is still created and thus takes additional memory. If you want to reduce that memory, you need to uncheck the Get resolution from MAX option, set the 3ds Мax resolution to a low value like 100 x 100, and then select your real output resolution in the V-Ray VFB options.
    Is it still the case ?
    Thanks !
    http://tatprod.com/
    Usually yes, however, It seems there is an issue in that regard (with the Max frame buffer) from recently. Thanks for the report! I've informed our developers about the matter and logged the issue (internal bug-tracker id: VMAX-9694) for further investigation. It will be fixed as soon as possible and it should work as described.
