in the Vray doc there's a line concerning the RAM consumption of the 3DS Frame Buffer
Is it still the case ?
Thanks !
Even though you select the V-Ray VFB as your output, the 3ds Max VFB is still created and thus takes additional memory. If you want to reduce that memory, you need to uncheck the Get resolution from MAX option, set the 3ds Мax resolution to a low value like 100 x 100, and then select your real output resolution in the V-Ray VFB options.
Thanks !
