I have a scene where I'm trying to render a few selected objects, including a white background. If I use IPR, it looks great, but when I go to do a production render, the background renders as black. Super annoying. No matter what I try, I can't get the background to render like it should when using Render mask Selected.
Selected object won't render
David Anderson
www.DavidAnderson.tv
Software:
Windows 10 Pro
3ds Max 2024.2.1 Update
V-Ray GPU 6 Update 2.1
Hardware:
Puget Systems TRX40 EATX
AMD Ryzen Threadripper 3970X 32-Core 3.69GHz
2X NVIDIA GeForce RTX 3090
128GB RAMTags: None
Presuming you're using the IPR debug shading to isolate the objects, yes, the background would be there. Render mask selected, however, works in a different matter and is meant for other procedures (i.e. re-rendering a specific object on-top of an already completed render), You can render your scene with the black background, take the alpha and use it as a mask in a simple composition with a white background
- Likes 1
Originally posted by aleksandar.hadzhiev View PostYou can render your scene with the black background, take the alpha and use it as a mask in a simple composition with a white backgroundDavid Anderson
Software:
Windows 10 Pro
Hardware:
128GB RAM
