Why does the Vray Sun and Sky Shadows not look Parallel. its a very basic setup literally just a vray sun and sky. The sky is in a dome light
Vray sun and Sky Shadows are not parallel
The sun's light casts shadows that are pretty much parallel
Your camera on the other hand is essentially showing you a perspective view, not a parallel projection or orthographic view.
This viewport screenshot may shed some light on the subject. As you can see the green boxes are parallel and just a single box instanced couple times without modifying the original one's rotation. However in cam view (default camera added)...
Kind Regards,
Morne
Originally posted by johnnelsonvfx View PostThat Image completely represents what i am running into. Thank you. Its just strange because the plate that i am rendering on top of has shadows that are parallel. .Dmitry Vinnik
Silhouette Images Inc.
ShowReel:
Run your renders (with some overscan!) through the same undistortion as the plate, and it should be a match.
Lele
emanuele.lecchi@chaos.com
Disclaimer:
