VFB not saving. Please help!
    Did you try saving to a vrimg, then restarting max and opening the vrimg back up to save out to something else?
    This problem just happened again on a colleagues machine. I tried to do as you suggest, but there doesn't seem to be a 'save to vrimg' button unless I am missing something.
    Looks like a series of screengrabs again!
    Kind Regards,
    Richard Birket
    http://www.blinkimage.com
      The vrimg save option is in the Frame buffer rollout. The image is saved per bucket as the rendering is happening.
      Seems to me you might be running out of memory. If the image is as big as it seems to be (9600x4800?) there probably is not enough continuous memory left for max to create the bitmap buffer to save it. Your best bet would be to render directly to a vrimg file, and maybe even without any of the memory framebuffers turned on. If this is the problem it will thankfully be gone when max goes 64 bit
      Torgeir Holm | www.netronfilm.com
        Thanks egz. Am I right that you can't save as a vray image after rendering though? This was the situation I was in.
        Kind Regards,
        Richard Birket
