Glass reflection
  • Glass reflection
    Is there a way to get rid of glass reflecting in the glass? I have an apartment interior that has windows reflecting on other windows and the client wants them removed. I am not sure if this is even possible, without turning off the glass.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    Trace sets?
      I will research it, thank you!
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        Trace sets don't seem to work. I exclude the one from the other, but it still reflects.
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
          Okay, it isn't the glass reflection happening, it is the sky. I'll have to figure something out.
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
            I had to copy my window backplate around until it blocked that sky reflection. All is good now.
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
              On a side note. How did you get your buckets to be different color in the VFB? Is it a setting? Possible a Vray 5 option?
                Yes, you can change this in the VFB settings. It's a new option that was introduced with Vray 5.
                Aleksandar Mitov
                www.renarvisuals.com
                office@renarvisuals.com
                AMD Ryzen 9 9950X 16-core
                96GB DDR5
                  Yeah, the bucket colors were that way by default.
                  Bobby Parker
                  phone: 2188206812
                  • Ryzen 9 5900x CPU
                  • ​Windows 11 Pro
                    I always wire the HDRI (instanced) through an output map for domelight, background, env. reflection and env. refraction separately, so you can perfectly tune these components.
                      What is the point of these different colors? Useful for render farms?
                        Definitely most useful for DR since you get one color per node. At first I found them distracting for normal rendering with a ton of cores on a single machine. Eventually, I decided I kinda like them, but they definitely can influence your perception (put one color next to something and it will make you see the compliment). The option can be turned off, setting them back to the grey squares they used to be.
                          Thanks, I was mostly curious whether they had any purpose on a single machine, but it doesn't sound like it.
