Multimatte element not working as expected
  • Multimatte element not working as expected
    Please check the image below. Why does my Multimatte channel look like this?
    Aleksandar Mitov
    www.renarvisuals.com
    office@renarvisuals.com
    AMD Ryzen 9 9950X 16-core
    96GB DDR5
    Could you send the scene to support@chaosgroup.com so we can take a look?
      Ok, email sent. Ticket number is 315-228-3075.
      Aleksandar Mitov
      96GB DDR5
        Thanks for the provided scene. Everything seems to be working fine. It is possibly a viewport hiccup since the diffuse filter and multimatte passes are next to each other. Does it save correctly on your end?
          I don't know, but I often see strange stuff happening with channels in Vray 5. Here's an older thread of mine where again strange stuff happened with MultiMateElement.
          Aleksandar Mitov
          96GB DDR5
            I cannot seem to reproduce it with the described steps. Do tell if you are able to, so we can investigate and try the suggested solution from the other topic.
              Ok, I'll try to keep an eye and remember what triggers this.
              Aleksandar Mitov
              96GB DDR5
                I just did a region render and everything outside the region in the rgb color channel appeared just like diffusefilter. very strange.
                  Same here! The problem occurred when I did a region render. Maybe that's what triggers the bug?
                  Aleksandar Mitov
                  96GB DDR5
                    Seems to be something to do with the denoiser. If I have a region going and the denoiser kicks in, it switches the area outside the region to something from a different pass. If I slide the denoiser opacity down, so disappears the mystery pass...
                      Pixelcon I am still unable to reproduce the issue. Could you send your scene to support@chaosgroup.com as well?
                        I'm afraid this scene cannot be shared. But i'll see if I can strip it down for you.
                          For future reference - here I've described what could be causing the issue: https://forums.chaosgroup.com/forum/...69#post1083469
                          Fix is in the works..
                          Yavor Rubenov
                          V-Ray for 3ds Max developer
