V-Ray Standalone doesn't render Hair and Fur (WSM)?
  • V-Ray Standalone doesn't render Hair and Fur (WSM)?
    Is there a way to render the Hair and Fur (WSM) from 3ds Max within V-Ray Standalone?
    Standalone (both Win and Linux) seem to completely ignore it. But maybe there's a setting I'm missing somewhere?
    3ds Max 2020.3 (22.3.0.3165)
    V-Ray 4.30.00 (build 00001)
    V-Ray Standalone, version Next Standalone, update 3.2 for x64, Build b4e50a4e from Apr 8 2020, 23:18:02, V-Ray core version is 4.30.02
    Thanks!
    Hair and Fur are not supported when rendering in Standalone. For more info you can visit our documentation site:
    https://docs.chaosgroup.com/display/...orted+Features
    Milva
    Milva Perkovich
    QA department
    Chaos Group
      In addition to Milva's comment, as a workaround you can go to the Hair and Fur modifier's Tools parameter and convert Hair -> Mesh. Alternatively, VRayFur could be used instead, all depending on the desired outcome.
      Nikoleta Garkova | chaos.com
        Thank you, this is great.
        Preview – Renders a local preview with V-Ray Standalone which is the closest approximation to the render output from Chaos Cloud.
        What are the differences between Standalone and Cloud?
        The workaround Hair to Mesh is helpful, but unfortunately it does not transfer any material settings. We will try to use VRayFur or another plugin instead.
          Ideally - none
          Peter Matanov
          Chaos
