Vray Gamma/Texture issue
  • Vray Gamma/Texture issue
    I was wondering if anyone can help me with, what I think, is a gamma issue.
    These textures are from CG Axis and I'm not getting the same result as their render, see below comparison
    Left My render. Right CG Axis Render
    Click image for larger version  Name:	comparison.jpg Views:	0 Size:	1.01 MB ID:	1098285
    Here is my grpah for the texture:
    Click image for larger version  Name:	Material-Graph.jpg Views:	0 Size:	593.5 KB ID:	1098288
    And finally my VRay Settings
    Click image for larger version  Name:	VRay-Settings.jpg Views:	0 Size:	128.2 KB ID:	1098287
    Max Version - 2020
    VRay Version - 5
    Maybe there's something else I'm missing. Any help would be great.
    Thanks,
    Keith
    It could be Max isn't set up properly (i.e. its gamma settings are at 1.0, and the map is set to pick those up.).
    Did you try forcing sRGB (or a .4545 gamma) in the bitmap? Did anything change?
    Lele
    emanuele.lecchi@chaos.com
    Disclaimer:
      Hi Lele.
      Max is set up for 2.2 gamma
Name:	Max Gamma.JPG
      I've also tried changing the bitmap to sRGB and .4545 gamma, it changes it a bit but again not the way the I would like. Even changing the inverse gamma around to match the original render.
      I've uploaded the file here if anyone wants to look at it - https://www.dropbox.com/s/zdnqhwoy8h...0Test.rar?dl=0
        Umh, from what i can see, there is nothing wrong with your setup, on the Max/V-Ray side.
        The render matches what the diffuse texture shows, by and at large.
        Could the problem be with the CGAxis render of the sample?
        Is there any way that can be shared too? Any app that needs downloading?
        Lele
        Disclaimer:
          Thanks for checking for me. At least I'm not going mad ha.
          "Could the problem be with the CGAxis render of the sample?" - It could very well be I'll search and see
          It's from this collection - https://cgaxis.com/product/cgaxis-wo...tion-volume-2/
