Install Error Vray 51000
  • Install Error Vray 51000
    Something went wrong. Click image for larger version
    Could you please check if the user which is running the installation have rights to write in the above mentioned directories?
    I can see that yoi are trying to install V-Ray in drive D:\Autodesk, but could you please confirm if 3ds Max 2021 is installed in the same directory?
    Could you please try to remove/delete V-Ray for 3ds Max first and then try to install it again:
    https://docs.chaosgroup.com/display/...ninstall+V-Ray
    Please confirm where is the exact 3ds Max 2021 install directory on the machine and where you are trying to install V-Ray exactly
    and if you user have the rights to write on the machines.
    Let me know if the above suggestion helped you.
    Stefan Isakov
    Technical Support Team Lead
    Contact Support
    Chaos
      I run the installer as Admin too, no problem with Vray 50005 and the nightlies.
      Now I lost my license.
      In addition, I delete manually all the Vray scrpits and now it works fine.
        Thank you for your reply. Let us know if any assistance is needed.
        Stefan Isakov
        Contact Support
        Chaos
