Vray 5.1 - crashes with multiple scenes
  • Vray 5.1 - crashes with multiple scenes
    I installed Vray 5.1 a few hours ago and now I'm finding that quite a few of my scenes made with Vray 5.0 are crashing upon rendering. At first I suspected that it's due to using Override Mtl, but then I tried a few other scenes that don't use Override Mtl and they crashed as well. So I'm thinking it's not strictly related Vray Override Mtl and it's a broader problem?
    Please see below some screenshots.
    I sent an email to support. My ticket number is 330-607-4433.
    Click image for larger version  Name:	vray_5.1_crash.png Views:	0 Size:	288.8 KB ID:	1103796Click image for larger version  Name:	vray5.1_crash.png Views:	0 Size:	252.2 KB ID:	1103797 Click image for larger version  Name:	vray5.1_crash2.png Views:	0 Size:	285.0 KB ID:	1103802
    Aleksandar Mitov
    www.renarvisuals.com
    office@renarvisuals.com
    AMD Ryzen 9 9950X 16-core
    96GB DDR5
    Alright, I think I found the culprit! The scenes crash only if there are Forest Pack objects in them. As soon as I delete them, the scenes render fine. I'm using Forest Pack Pro v7.0.3 Beta. Would the issue go away if I install the latest official release of Forest Pack instead of the beta? This should be v6.3.1.
    Aleksandar Mitov
    96GB DDR5
      Hm do you think you can get me a crashing scene to vlado@chaosgroup.com? We test Forest Pack, but I'm not sure we tried the beta builds.
        Sure. I've just sent you an email. Thanks for looking into this.
        Aleksandar Mitov
        96GB DDR5
          I found the same problem with RailClone Pro v4.2.1, but problem only with 1 reailcone object, if I delete it everything start to render. if I put this RailClone object into new scene it rendering
            Hello!
            We're already working on the problem with ForestPro, thank you Alex_M for the scenes!
            Regarding the RailClone Pro v4.2.1 case - I believe it may be a different issue due to instancing differences between the versions of the iToo plugins used, and therefore it may not be automatically resolved with the same fix. Mikhalenko , could you please share an excerpt of your RailClone scene so we could reproduce the crash and investigate the problem? Please, send it to me at margarita.stoeva@chaosgroup.com
            Thank you in advance!
            Margarita
            Margarita Stoeva | chaos.com
            Chaos QA (V-Ray for 3ds Max)
              Hello
              Thank you both Alex_M and Mikhalenko for the provided scenes!
              We managed to fix the crash and improved the release thanks to your quick feedback!
              You can re-download the new V-Ray 5 Update 1 installations from Chaos site now and enjoy rendering ForestPro and RailClone safely.
              We deeply apologize for the inconvenience! Many thanks!
              Margarita
                Thanks so much for the quick reaction!
                Aleksandar Mitov
                96GB DDR5
