Originally posted by kambysia_karl_hakimmeibodi
View Post
V-Ray Cosmos issue
Jackie Teh
3ds max design 2023, V-Ray 7 [7.00.03 build 32836]
AMD Threadripper 1950X @3.40 GHz | 64GB RAM | Nvidia RTX 3070 ti
Originally posted by jackieteh View Post
Do you block 3ds max internet connection?
Cheers!
Originally posted by kambysia_karl_hakimmeibodi View Post
Hi, no we have no such thing set up here, however our network infrastructure is handled by an external company, they set up all our PCs to be in a domain etc. could it be that the domain settings are blocking it? Is there any way to check or some particular info I could forward to our admins?
Cheers!Best regards,
Jackie Teh
Can you also check if your Firewall/antivirus configuration is not blocking the 3ds max or Chaos Cosmos connections/disable them and see if the issue persists? If you're still having issues, would it be possible to contact us through our contact form so you can get further assistance?
Edit: Sorry, just saw there are more posts below disregard this message - however, do check with the external company as already suggested, and get back to us if they are not able to assist.Nikoleta Garkova | chaos.com
Hi nikoleta.garkova
I haven't received any help from your support yet.
Is it normal?
Because I still dont have the Cosmos
newzboy did you manage to contact us through https://www.chaosgroup.com/help/cont...scene#options? I cannot find a ticket from you on our system, if you've reached us you should've received a ticket reference number - can you share the digits so I can find it? Thanks!
I have got the same error, and found out that I am unable to start the cosmos browser service. Perhaps it's the same for the threadstarter, Did you solve this?
EDIT: Solved. I actually forgot the correct syntax in the json file as you mentioned. Just added one more \ and then it worked.1 PhotoLast edited by chroma; 19-03-2021, 02:35 AM.
- Likes 1
