NHANDLED EXCEPTION: Applying render effects
  • NHANDLED EXCEPTION: Applying render effects
    It's killing me! I have tried for two days to render this out. It was rendering fine until I upgraded to 5.1.
    [2021/Feb/28|12:02:25] Calling endFrame().
    [2021/Feb/28|12:02:25] Calling endFrame() in the main thread.
    [2021/Feb/28|12:02:25] Entering endFrame().
    [2021/Feb/28|12:02:25] Broadcasting NOTIFY_POST_RENDERFRAME.
    [2021/Feb/28|12:02:25] Applying render effects.
    [2021/Feb/28|12:02:26] error: UNHANDLED EXCEPTION: Applying render effects.
    Last marker is at D:\cgrepo\vray\vray\src\vrayrenderer.cpp, line 5566: Preparing global light manager
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    Do you have any effects in the Effects tab in the Environment and Effects tab ?
    Yavor
    Yavor Rubenov
    V-Ray for 3ds Max developer
      I do have PSD Manager and VRayAerialPerspective. It happened on another project as well.
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        Could you try without them - or send a scene to our support ?
        Yavor Rubenov
          Yes, I'll sure try if it happens again. If not, I'll send the file. I suspected it was PSD Manager, but it isn't happening on my newest projects.
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
            If you have a scene file I would be happy to look at it too. So far I'm not aware of any V-Ray 5.1 specific issues/changes that would effect psd-manager 5 and would require a change on the psd-manager side.
            Do you recall if the PSD file was saved successfully when the error occurred (or if not could you save it later via "Save Now")?
            Daniel
            Daniel Schmidt - Developer of psd-manager
              No, PSD Manager didn't save.
              Bobby Parker
              phone: 2188206812
              • Ryzen 9 5900x CPU
              • ​Windows 11 Pro
                Empty file (0 bytes) / partially saved file / no file saved / previous file not overwritten / don't know?
                Did you try saving using psd-manager 5's "Save Now" button after the error occurred?
                Daniel
                  It crashed with the PSD Manager still saving.
                  Bobby Parker
                  phone: 2188206812
                  • Ryzen 9 5900x CPU
                  • ​Windows 11 Pro
