I thought I was going mad but I have tested this multiple times again today.
In the Time panel, the Start Frame only relates to 30fps. So with 25fps this starts at the wrong frame.
Yes, I can offset that to compensate but I am unsure whether the sequence will be affected in any other way, so not ideal unless you can assure me that it won't
Any chance of a quick fix for this please? I have 75 sequences I need to start work on and this will quite greatly hamper my progress.
EDIT: Bizarrely after 3 hours of trying this has now started working as it should, for who knows what reason.
I made a test scene where you can see it happening though, which I tested, flipped back and forth to check it was happening.
I'll recreate that later and post it here.
