Hi
I had to switch the mainboard to exactly the same model due to failiure. However, everything is working, windows is activated again, I have no problems...
...except for one strange behavior with max 2021, I didn't had before! I currently work with 2020 because of this
Please checkout the video:
https://vimeo.com/561034189/1d6bd5b5e0
After several quick autobackups, from around the 4th time, the process freezes the system up to a minute.
The file itself is saved in a fraction of time, but max hardly comes back. This effect is repeatable.
Once this happensduring autoback, the ordinary save action is "infected" with the bug as well.
I deinstalled 3ds max 2021 from my system and cleared those folders from remaining files and folders:
C:\Programme C:\Users\me\Documents
C:\Users\me\AppData\Local\Autodesk\3dsMax
C:\Users\me\AppData\Roaming\Autodesk\ADPSDK\3DSMAX
Then I reinstalled Max 2021 and afterwards did the security patch to "2021.3.2 Security Fix"
Beside the addition of some custom scripts via startup, nothing was changed or added.
The Autobackprocess went flawless. After installation of vray_adv_51002_max2021_x64.exe I had the issues like shown in the video.
A Vray uninstall fixed the problem, so autoback was working again.
I tested vray_adv_51001_max2021_x64.exe with the same error. vray_adv_50003_max2021_x64.exe and vray_adv_50004_max2021_x64.exe worked with no errors, so somewhere in between those versions, there must be a bug.
Since I retrieve the Vray license via VPN, I wanted to make sure, it is no time out problem, So I did a test with the VPN turned off, but this had no effect.
regards
Michael
regards
Michael
