Exclude OneDrive from the default material library destination
  • Exclude OneDrive from the default material library destination
    Add an option to exclude OneDrive from the default material library destination (%userprofile%\Documents).
    The Material Library Browser can't view the libraries on OneDrive.
    Many Windows 10 users use OneDrive for no apparent reason.
    OakCorp Japan - Yuji Yamauchi
    oakcorp.net
    v-ray.jp
    This problem seems to be that the path of "Document" is registered in the characters of the OS local country in the OneDrive enabled environment.
    Like this C:\Users\[Username]\One Drive\ドキュメント\V-Ray Material Library
    On Japanese OS, Japanese characters "ドキュメント" are entered in the material library path and it does not work properly.
    That is, support multibyte characters in the material library path.
    oakcorp.net
    v-ray.jp
      Thank you for the report. I'll notify the developers about the matter.
      EDIT: Logged the issue (internal bug-tracker id: VMAX-11304).
