V-Ray Materials
  • V-Ray Materials
    It is really screwing me on deadlines. I apply a UVW Map and it ignores it at render time.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    Weird....any specific material I can try here?
    Oh, I see what you mean. It is only those which have a triplanar texture, which overrides the uvw modifier as the triplanar is the mapping source
    Well it could be something different but that's what I observe as one reason.
      Bobby, could you send me a little piece which is misbehaving?
      The geo and the shader?
      Lele
      emanuele.lecchi@chaos.com
      Disclaimer:
        Here is a render. The base has some black tile (first images) from the library and the fascia (second images) has wood from the library, both rendered in the wrong direction. I double-checked and the mapping is correct.
ID:	1119522Click image for larger version
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
          Could you send me just the two geometry bits as max files (i.e. select, then "save selected"), with their associated materials?
          Lele
          Disclaimer:
            Yes, of course. When I go back into the project I'll save just those two elements and send it over.
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
