3dsmax noise map + uvw randomizer
  • 3dsmax noise map + uvw randomizer
    does 3dsmax noise works in conjunction witth vray uvw randomizer?
    Surrealismo
    https://www.facebook.com/surrrealismo
    The VRayUVWRandomizer requires a "Mapping source" input, which the 3ds Max native noise map does not have. You may bake the noise tex (right-click in ME>Render Map) and use the image through a VRayBitmap if you wish.
      but is it possible to implement as in corona?
      Surrealismo
        The CoronaUVWRandomizer works in a different matter (as an intermediary node), hence why procedural textures work with it. I'll mention the suggestion to our developers and we'll see if we can implement such a functionality in the VRayUVWRandomizer too.
          thank you aleksandar, that would be great
          Surrealismo
            I echo that this is something I've often wished for as I use the noise map ALL the time. Please mention it to dev team!
              You could add the idea to the Portal so people can vote on it.
                It may not be exactly what you need, but Jonas Noell had a great tip about using a noise map with a VrayTriplanar map to get some random variation (starts at 8:30):
                  done! feel free to vote good people
                    thanks a mil - I started watching that but ran out of time. Will definitely finish - his tuts are brilliant
