Glass material : background appear darker
  • Glass material : background appear darker
    Hello,
    Since a long time, I use a background map in screen mode. When I have a glass material, the background appear really darker. I'm trying to check all options to solve the problem without succes. Thanks for your help !
    For exemple, I have a plane, a sphere with transparent glass, a background plane (trees) and a background map (sky)
    The render result : the reflexion is ok, but the transparence is darker
    Here is some settings :
ID:	1123007Click image for larger version
    Could you attach the scene from the screencap here so we can take a look?
      Hello, thank you for your answer. I attach the scene here
      WeTransfer is the simplest way to send your files around the world. Share large files and photos. Transfer up to 2GB free. File sharing made easy!
        Thank you for the provided scene. The issue stems from the "Affect Background" option in the Color Mapping settings (Render Setup>V-Ray>Color mapping). It seems to affect the Exposure control as well. I've logged the matter (internal bug-tracker id: VMAX-11361) for developer investigation. Re-enabling the option should resolve the issue. Is there a reason to disable it, maybe we can work around that as well?
          Thanks for your help. I uncheck "affect background" option for the reason that the background appear really darker. How can I have a background that appear like the original bitmap ?
            Since you have an Exposure Control activated, control the lighting through there (Increase ISO or decrease shutter speed/f-number). Another way to adjust the lighting, is through the "Auto-Exposure/Auto-WB" (Render Setup>V-Ray>Camera); lower the VRaySun intensity (f.e. 0.01), activate the Auto-Exposure/Auto-WB and render.
