MAx 2022.1 Vray 5.1.3 with freshly installed substance(sbsar) crashes or loses connection to the shader.
  • MAx 2022.1 Vray 5.1.3 with freshly installed substance(sbsar) crashes or loses connection to the shader.
    Hi all, I will post this in Adobe Substance forums too. I am trying to use an sbsar shader with the substance2 map connection to a vray material. I just tweaked the colour corrections a bit but in general it is a vanilla connection. So i start working and everything looks fine ... but after a while the shader loses connection. It appears white or black and then in general things crash. I have done two or three projects without substance so far and i didn't have any issues. So i am relatively confident that this issue is substance - vray related. Is there an updated susbstance plugin ? Am i doing anything wrong. I just load the sbsar file on an empty substance2 node and then I click substance to vray.
    164 core mini rendering farm - RTX 3090
    All with 128GB ram
    Windows 11
    3ds Max 2024 - vray - phoenix - forest pack
    Are you getting something like this:
    After long scene testing with the Substance 2 map, the connection between the diffuse slots was missing and there was a crash when the Displacement was disconnected at the end. I'm not sure if this is a V-Ray issue actually, will perform more tests to see how it behaves with the other engines.
    Tashko Zashev | chaos.com
      Hi Tashko ,
      No the material links are normal, but the render output is black for the substance material. It is difficult to replicate but i got it twice without touching the material. Randomly after a normal progressive render the next one turned black ... then no matter what I did the material couldn't render properly. I restarted max or the whole machine and it was fixed. I got it twice yesterday but not today (even though I am not doing that many renders today). I rendered two animations all fine ... I haven't discovered why it crashes. My gut feeling is that it is some sort of cache memory that gets corrupted ... but I am not a developer.
      All with 128GB ram
      Windows 11
        I have forest pro 7+ , vray 5.1.3 max 2022.1 a 32 core threadripper and a 3090 rtx . The system is brand new with max -vary and adobe premiere, photoshop and susbtance, Windows pro 21H1
        All with 128GB ram
        Windows 11
          Random issues are difficutl to catch, but we can try your setup here if you can send a sample or the entire project. You can use the "Submit a request" from https://support.chaos.com , we have an option to upload files.
            Ok i am uploading an archive , Thank you. I finished the project but it will be great to catch the bug ...
            All with 128GB ram
            Windows 11
              Hi guys,
              I used to get this happening a lot as well, I gave up using the substance link for about a year, recently tried it with the new updates to all the software and it's definitely less of an occurence, alas it still happens.
              I feel your pain Alex, only way I got it to work is to reload the material again. Strange that this hasn't been picked up before.
              As yet I can't figure out the trigger.
              Cheers,
              Jason
              AMD Threadripper 3990x 64C Processor, 128 GB DDR4-3200 Ram, 48 GB PNY Quadro RTX A6000, ​Windows Pro 10.0.19045.4894, 3dsmax 2025.3, Vray 62006, Vantage 2.5.2​
