Vr-ay Exposure Camera Node disallows camera selection
  • Vr-ay Exposure Camera Node disallows camera selection
    V-ray Exposure Camera Node disallows camera selection -
    I have had this issue in 5.x and now 5.2 V-ray.
    When I use V-ray Exposure Control, the select camera button will not list any cameras.
    Is there a special way to add a V-ray physical camera to the camera node?
    Or is there another setting that must be enabled (or disabled) to permit camera selection for the Camera Node setting?
    TIA!!
    I do not understand what you mean. Could you clarify with a few screencaps?
      here it is.
      Where "camera node" says None, I do not know how to select the desired camera.
      TIA!!
        After you press "none" you can click on a camera in viewport.
        Alternatively, you can click on a camera in the scene explorer.
        Lastly, you can press H and bring up a floater of the scene explorer used to select.
        Lele
        emanuele.lecchi@chaos.com
        Disclaimer:
          I must be a dunce.
          But in my defense, I always hide the cameras in my scenes.
          Thank you Lele!!
            Originally posted by lbpalm View Post
            I must be a dunce.
            Thank you Lele!!
            Ahah if so, then that makes two of us!
            Not only the hiding, but also the filtering on the selection panel should be considered. XD
            Lele
            Disclaimer:
              yes, understood.
              Thanks!
