AND ryzen threadripper 3990x Ram Maxing out issue
  • AND ryzen threadripper 3990x Ram Maxing out issue
    Hi Guys,
    I am running into a Ram maxing out issue, with our thread ripper machine
    on a Ryzen 5950x 64gb of ram a scene renders fine with ram sitting about 55gb between 80-90% steady,
    However on a machine with thread ripper 3990x 64gb of ram it maxes out 100% and also the m.2 ssd is on 100% also (thinking because its trying to use ssd to help with ram)
    we upgraded the ram to 128gb and it still maxes out ram and ssd
    causes render times to not finish freezing up the machine
ID:	1132704Click image for larger version
    any ides what the issue could be?
    Are you rendering an identical scene?
      Alex's question is quite apt: if you changed, f.e., resolution on the second machine, and you had, f.e. .TX files, displacement with edge length in pixels, and so on, the memory requirements may change, even a lot.
      The render log should provide for info on where the memory is being used.
      Lele
      emanuele.lecchi@chaos.com
      Disclaimer:
        @hermit.crab
        @^Lele^
        both computers are rendering identical scene and settings
        ill try another render with increased log information and come back to you
