Vray5. 2x vrayies has some errors in MAXscript
  • Vray5. 2x vrayies has some errors in MAXscript
    For example, ExcludeList and includelist and inclexcltype
    I don't know if there are any more mistakes.
    These are normal at 5.14
    And this error has never occurred in previous versions
    This problem leads to abnormal problems in 3D scripts made with this function
    Figure 1 shows 5.14 and Figure 2 shows 5.21
    Click image for larger version  Name:	image_68947.png Views:	5 Size:	11.5 KB ID:	1133715
    Click image for larger version  Name:	02.png Views:	0 Size:	2.1 KB ID:	1133717
    I can confirm it's a bug: the properties are shown when using "show", but can't be directly queried. ( VMAX-11718 )
    Lele
    emanuele.lecchi@chaos.com
    Disclaimer:
      I hope they can solve this problem soon.
      I haven't used the method you said.
      How to show?
        Code:
        show $
        will print out all the properties of the selected node (in your case above, the ies light).
        Lele
        Disclaimer:
          Code:
          show $
          Ha ha ha ha
          OK, I may have misunderstood
          I thought you used the show command to query the ExcludeList
          Look forward to repair
          Otherwise, my tools are unavailable
            Code:
            show $
            I'm not sure if the VRay techs know this already?
            How should I let them know about this problem?
            Keep this session up to date?
              ( VMAX-11718 )
              This is our internal reference for the bug.
              If you see something analogous to this in a thread, then you can be sure the bug has been filed, and the devs are aware of it.
              In general, however, they are ever present on the forum, and read everything with great attention.
              They just don't reply, as they're way too busy, normally, with other stuff.
              Lele
              Disclaimer:
                This is now fixed, in v 31180.
                Check the stable nightlies in a day or two: if a build with that number, or above, appears, download it to get the issue resolved (at the time of writing, the latest stable is 31179).
                Lele
                Disclaimer:
                  Thank you for your help
                    Correction: the build was in a different branch.
                    The fix will be coming soon enough in the main branch.
                    For now, the bug is still present.
                    Lele
                    Disclaimer:
