Hard to say without more information. Does it happen in a particular scene? If yes, could you send it to us (or attach it here)? If not, could you share the reproduction method? Also, which V-Ray and host platform versions do you have installed? Screencaps would be nice as well.
Thanks.
I've attached some data. It's not the original file - it's a simple test file - but the same thing is happening. I've included some output frames.
I'm using V-Ray 4.30.03 build 30952 in max 2020.
edit: I forgot to add .. this data renders fine locally.
Thanks for the provided scene. I rendered it through Deadline (V-Ray 4.30.03, build 31225) and no flickering is present. Which render manager are you using? Are there any errors/warnings?
Tested it with Backburner as well - no issues. Does it happen in every scene and/or with every normal map? Could you retry with the latest V-Ray NEXT stable build?
