I've noticed that during rendering VFB doesn't refresh buckets. I mean - buckets are moving, but image in their place looks still as calculated lightcache. I have to switch to lightmix and back to rgb to refresh already calculated places. Where can be the problem? It is lates version of Vray 5, rendering on bruteforce + lightcache. Sometimes also whole framebuffer is blinking ( appearing and disappearing ) and i can't stop rendering process until it's ended. I don't think it's gpu drivers issue. My hardware is Threadripper 3990, GTX 1080 Ti, Windows 10.
issue with VFB refreshing during rendering
Originally posted by kosso_olli View PostDid you probably refresh Lens Effects or Sharpen/Blur manually? This will also cause that behavior.
Originally posted by vladimir_krastev View PostHi are you rendering with V-Ray CPU or V-Ray GPU?
Can you share a video of the issue with refreshing? If your rendering uses too much memory and it exceeds your available memory for brief moments this could cause such effects.
Originally posted by vladimir_krastev View PostHI I tested this in a simple scene and it is not reproducing. Is this issue happening only in this scene or in any scene that you have created?
