Vray 6 Framebuffer terrible Slow while saving
  • Vray 6 Framebuffer terrible Slow while saving
    hi together,
    anyone else also getting extremly slow save performance in framebuffer using saving all image channel in one file?
    please have a look into it. thanks!
    bye
    jens
    Not at all on my side.
    If you have a high-resolution image, with many render elements, that may equate to a big file size.
    And depending on where it gets saved, it could become slow.
    Could you be more specific?
    For example, what's the image size, and what is the speed of the drive it's being saved to? (f.e.: 210 MB on a platter drive will take at least 7 seconds, assuming it's out of cache and writing at disk sped of 30MB/s.)
    Lele
    emanuele.lecchi@chaos.com
    Disclaimer:
      Hi Lele,
      we also used this workflow to save the image in that way from the framebuffer to networkdrive over 10Gbit connection. and yes it is correct that our file sizes are up to 2GB each frame becaue of high resolution and channels but we can compare it to the vray 5 version before that it is way more slower with the vray 6 version, even it is a smaller file size, it seams at the end of the saing process the framebuffer/max or whatever is wainting for anything...
      it happens on all workstation and is not related to any specified scene...
      bye
      jens
        Ah, thankyou.
        The detail of the comparison with v5 is very helpful.
        We'll look into it.
        Lele
        Disclaimer:
          many thanks!
            Thanks so much for the report.
            The issue is real, it's more prominent in some specific situation, and a fix is being researched.
            Lele
            Disclaimer:
              anything i could help?
                You well did!
                The devs found the cause (a fix for something else, and some unfortunate combination of factors) and will implement a fix ASAP.
                In the meanwhile, the save raw file dialog in the render options is unaffected and saves at full speed.
                The result should be exactly the same for image contents if you save an OpenEXR.
                Lele
                Disclaimer:
                  okay great! if a nightly is ready please let me know!
                  many thanks!
                    Originally posted by ^Lele^ View Post
                    You well did!
                    how are you saving exactly to bypass the slowdown? does not work at my end for now. 15sec renders are taking ~2mins..
                    any hint about the cause of this would help I guess.
                    Marcin Piotrowski
                    youtube
                      Through the raw file save dialog in the render settings.
                      Lele
                      Disclaimer:
                        This is now fixed in Hotfix 1.
                        Lele
                        Disclaimer:
                          great news! many thanks Lele!
                            I'll be sure to pass the thanks to the devs!
                            Lele
                            Disclaimer:
                              simple write a script for it ,-)
                              btw. i ask for another fix a while ago..it was tracked under VSLANG-129.
                              could you tell me the status ?
                              thanks!
