IPR caused PC to be almsot unusable
  • IPR caused PC to be almsot unusable
    Not sure if there is something wrong with my PC but I've noticed since updating to Vray 6.0 that while using the IPR (either in VFB or viewport) it becomes almost impossible to interact with anything else with 3ds max's interface. It becomes exceedingly slow and unresponsive, like Vray is hogging all GPU resources. Windows 10 in general is more sluggish too. There used to be an option to use low thread priority but that is no longer there and not a good solution anyway. Why is this happening?
    Hey justini
    Are you using V-Ray GPU ?
    Are you using the AI Denoiser?
    If yes, go to the performance tab you will find low priority checkbox next to your rendering device. This should be helpful
    If you are using the standard V-Ray CPU, you can reduce the frequency of updates for the AI denoiser/V-Ray Denoiser. The setting is called Post Effect Rate
    Best,
    Muhammed
    Muhammed Hamed
    V-Ray GPU product specialist
    chaos.com
      Originally posted by Muhammed_Hamed View Post
      Hey justini
      Best,
      Muhammed
      no. not using Vray GPU. Just standard CPU, but doesn't IPR use both?
        Not really, Your GPU should be near idle if you use standard V-Ray CPU IPR, unless you have the Nvidia Denoiser and Lens effects enabled
        Muhammed Hamed
        chaos.com
          The option is now always on.
          It however seems to be an issue with the CPU being hogged, for whatever reason, but i didn't manage to reproduce it with the scenes i tried.
          Do you have anything you could share that shows the behaviour on your side?
          Lele
          emanuele.lecchi@chaos.com
          Disclaimer:
