Vray Proxy Creation displayes incorrect Proxy Mesh
  • Vray Proxy Creation displayes incorrect Proxy Mesh
    Hello. Occasionally if I'm working on a large scene, the proxy creation process seems to glitch out. If I create a proxy of a chair for example the proxy display mesh might show as a completely different proxy mesh used somewhere in the scene (like a 3D person or a plant). I tried re-setting the proxy display cache, but this had no effect. Is there a trick to fixing this other than re-starting Max?
    Hi are you using the preview override:
    Also what happens if you for instance switch the proxies to box and back to faces? Will this resolve the preview issue?
    Vladimir Krastev | chaos.com
      Hi Valdimir - thanks for the reply. No I was not using preview override. Just had to jump on to another project. I've re-opened the file I was working on and the chair I was trying to proxy now creates the decimated proxy mesh exactly as it should. Just one of those transient problems I guess. Next time this happens I'll experiment with the proxy display as you suggested. Cheers
        Hi thanks for the follow-up. If you get in trouble again please write us here or through the contact form.
