VRay 5.2 Scene Converter Handler Exception
  • VRay 5.2 Scene Converter Handler Exception
    Hello,
    I'm getting this handler exception when using the VRay Scene Converter.
    How do I go about this, and is there way to identify the object/materials that are at fault?
    This is something else, not dependent on what is being converted: the max version checking seems broken, but in a creative way.
    Is the vrutils.ms file in its original form?
    Lele
    emanuele.lecchi@chaos.com
    Disclaimer:
      It's a clean VRay install no edits to the ms file.
      However, we use a lot of custom scripts, not sure if that has an effect.
      Can I get a clean/new ms file to compare?
        The file is in the path written in the Maxscript editor bar.
        If you make a copy of that file, and then reinstall V-Ray, you should be able to compare the two.
        Lele
        Disclaimer:
