I've noticed that the VFB window doesn't move smoothly when I'm dragging it around quickly. If I'm moving it slowly, it doesn't hitch.
VFB window doesn't move smoothly when dragging it around
Aleksandar Mitov
www.renarvisuals.com
office@renarvisuals.com
AMD Ryzen 9 9950X 16-core
96GB DDR5
GeForce RTX 3090 24GB + GPU Driver 566.14Tags: None
Yes, you can download the video here (link expires in 7 days): https://we.tl/t-wHHQhYzdoT You can clearly see that other windows such as the Material Editor move perfectly smoothly. It's only the VFB that's stuttering while being dragged around. It's pretty jarring.
This happens on all workstations here. One of the workstations (the one in the video) has a fresh Windows install with the latest updates and the latest drivers and there's nothing running in the background that takes CPU or GPU resources. I don't remember this problem happening with earlier versions of V-Ray.Last edited by Alex_M; 01-11-2022, 03:56 AM.Aleksandar Mitov
96GB DDR5
On the PC where I recorded the video I have only 1 monitor. The other workstation where the problem also appears has 2 monitors.Aleksandar Mitov
96GB DDR5
It does, but it appears to be much less severe. It's very pronounced in complex scenes though to the point of being a hassle to move the window around.Last edited by Alex_M; 11-11-2022, 06:12 AM.Aleksandar Mitov
96GB DDR5
yeah im getting this too..very stuttery. I cant help feeling im having a lot of driver related issues with vray 6, so many crashes, restarts needed etc, on basic scenes too.
Heres a video of lag
https://drive.google.com/file/d/14MR...usp=share_link
- Likes 1
I see.
Does the behaviour disappear if the VFB window is dragged AWAY from the Max ui, into empty desktop space?
I have a feeling the issue isn't with the VFB per se', but with the need to redraw the non-Qt Max UI.
Could someone with the issue kindly test this?Lele
emanuele.lecchi@chaos.com
Disclaimer:
Originally posted by francomanko View Poststill lags for me when over empty desktop space.Aleksandar Mitov
96GB DDR5
- Likes 1
Would you kindly try two different things?
First, close the scene explorer, see if the issue of the glitching persists.
Then, with the scene explorer open, open a Max VFB, and minimise it. See if our VFB drags around as expected.
It feels like a fight for focus bewteen some parts of the Max UI and the VFB, i'll keep investigating, and keep you posted as soon as we can repro the exact behaviour and file a bug report (i.e. it's in our powers to fix.).Lele
Disclaimer:
I found out what triggers this! It has nothing to do with the Scene Explorer. It happens only if the VFB window touches the bottom edge or the right edge of the screen while moving it around. For some reason it doesn't happen when it touches the top edge or the left edge of the screen. It's still strange though why only the VFB has this issue. Other Max windows such as the material editor doesn't lag no matter which edge of the screen it touches while moving it around.Aleksandar Mitov
96GB DDR5
Originally posted by Alex_M View PostI found out what triggers this! It has nothing to do with the Scene Explorer. It happens only if the VFB window touches the bottom edge or the right edge of the screen while moving it around. For some reason it doesn't happen when it touches the top edge or the left edge of the screen. It's still strange though why only the VFB has this issue. Other Max windows such as the material editor doesn't lag no matter which edge of the screen it touches while moving it around.
Could you verify the two cases i mentioned?
We're trying on our end, but the reproducibility is sketchy at best, even on different workstations.
Lele
Disclaimer:
