For the past year or so I've been having this problem where deleting a bunch of materials from the slate material editor causes Max to crash. Does anyone else experience these crashes? I have a 3dsmax_minidump.dmp file of the crash if this helps?
Deleting materials from the slate material editor causes crashes
www.renarvisuals.com
office@renarvisuals.com
AMD Ryzen 9 9950X 16-core
96GB DDR5
GeForce RTX 5090 32GB + GPU Driver 572.83Tags: None
Sure. Please see attached.Aleksandar Mitov
96GB DDR5
- Likes 1
Ok, thanks. I will try.Aleksandar Mitov
96GB DDR5
I've just had the same crash with V-Ray 7. Another dump file attached. It doesn't happen ever time. It mostly happens when I've worked on a scene for more than half an hour and then I delete a complex material or a lot of materials at once.Attached FilesAleksandar Mitov
96GB DDR5
Originally posted by Alex_M View PostI've just had the same crash with V-Ray 7. Another dump file attached. It doesn't happen ever time. It mostly happens when I've worked on a scene for more than half an hour and then I delete a complex material or a lot of materials at once.Yavor Rubenov
V-Ray for 3ds Max developer
Interesting. So it's 3ds Max bug?Aleksandar Mitov
96GB DDR5
I remember having this problem a couple of times, years ago though, don't have those issues anymore, but I'm using 2025 now, so they might have fixed something.
- Likes 1
