OCIO environment variable
  • OCIO environment variable
    Hello, I haave a question about OCIO/ACES in VRay6.
    Why are the dropdowns for "input Colorspace", "Display Device" and "View Transform" disabled when you use an environment variable for OCIO config? I would still like to be able to choose between different view transforms. Am I doing something wrong?
    If I don't set the VRAY_VFB_OCIO_VIEW_TRANSFORM to anything it "unlocks" the dropdown but when I choose something else than sRGB nothing happens it still choses sRGB.
    Thanks!
    /Andreas
    Hi, I think something is wrong with the way the variable is linked.
    You could check this page for more information.
    https://docs.chaos.com/display/VMAX/...OConfiguration
      Hi, this is expected behaviour. It has been upgraded in V-Ray 6. Once we have environment variables set-up they will always override the settings in VFB once the scene is closed and opened again. So leaving the dropdowns active can be confusing.
      Vladimir Krastev | chaos.com
