Viewports break after rendering with DR/Distributed Rendering
  • Viewports break after rendering with DR/Distributed Rendering
    Since V-Ray Next I've been having this problem where rendering with DR causes my viewports to totally get bugged and all objects and even viewport labels disappear. Please check the screenshot below. The only way to solve the issue is to close Max and start it again, but the issue occurs again if I render another image with DR turned on. This really hurts my productivity when I have a lot of renders to do with DR turned on since I have to constantly close and open Max. I've had this issue since I had my previous workstation which had totally different hardware parts from my current one so I think it's not hardware related.
    Aleksandar Mitov
    www.renarvisuals.com
    office@renarvisuals.com
    3ds Max 2023.2.2 + Vray 7
    AMD Ryzen 9 9950X 16-core
    64GB DDR5
    GeForce RTX 3090 24GB + GPU Driver 565.90
    HI thanks for posting. Is this issue happening in every scene even a new simple scene? Please try reinstalling your V-Ray and 3ds Max.
    Vladimir Krastev | chaos.com
      Hi, Vladimir. Yes, it happens in pretty much every scene as long as I do enough renders with distrubuted rendering turned on. It could be the first render, it could be after the 5th. I'm currently using a brand new Ryzen 7950x PC due to a problem with the one from the signature. All hardware components are different on this PC and the problem still appears so I doubt that reinstalling V-Ray and 3ds Max will fix it.
      Aleksandar Mitov
      64GB DDR5
        Hi you could open up a ticket trough our support contact form and eventually we can try to help by logging into your computer and check what's going on.
          This issue still persists. Unfortunately, I won't be able to give you remote access to the PC. Is there another way to resolve this issue? This has been happening for years now and it's extremely annoying to have to restart 3ds Max after every other rendering I do with DR on.
          Aleksandar Mitov
          64GB DDR5
            Major bug!
            Bobby Parker
            www.bobby-parker.com
            e-mail: info@bobby-parker.com
            phone: 2188206812
            My current hardware setup:
            • Ryzen 9 5900x CPU
            • 128gb Vengeance RGB Pro RAM
            • NVIDIA GeForce RTX 4090
            • ​Windows 11 Pro
              Hey all,
              Revisiting this thread as the problem persists on many of our workstations.
              The 3dsmax viewports turn to flat grey color after rendering with V-ray.
              Same as OP in this thread.
              We have this problem on different Gpu setups, and using the recommended Gpu drivers as noted by Chaos.
              Any insight would be appreciated since we have to restart max every 15 mins because of this.
              Cheers!
                Hi, have you tried switching the display driver in 3ds Max?
                  Isn't the display driver set to Nitrous Direct3D 11 by default? Or are you suggesting to use a driver different from Nitrous Direct3D 11? If the latter, won't that degrade viewport performance?
                  Aleksandar Mitov
                  64GB DDR5
