I just updated my V-Ray to todays' update and my lightcache is rendering black. What gives? Not a huge deal with progressive, since I get a preview pretty fast with BF, but with buckets, my preview is a bucket at a time.
Black Light Cache
Black Light Cache
Bobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090 X2
- Windows 11 Pro
Tags: None
No, nothing. I have been rendering all day. I noticed the update text on the VFB, updated, and this is when the LC stopped showing. I'll reboot MAX when I get a chance; maybe it'll fix itself.Bobby Parker
phone: 2188206812
- Windows 11 Pro
Weird. Could be a bug. I don't know. I just know some features disable LC previews.
Boy you sure do rarely restart Max, eh? I do it every chance I get just to clear everything out. Not sure how you could update VRay with Max running, though.
I closed MAX to update.Bobby Parker
phone: 2188206812
- Windows 11 Pro
This is still happening, and no, there is no log errors. After a Google search, it is a know issue, but no resolutions.Bobby Parker
phone: 2188206812
- Windows 11 Pro
Originally posted by glorybound View PostThis is still happening, and no, there is no log errors. After a Google search, it is a know issue, but no resolutions.
Send a scene to support. There is likely an easy fix. If there is not then there is a bug they need to know about so they can fix it.
- Likes 1
Unfortunately, it’s a very large scene, but I’ll try.Bobby Parker
phone: 2188206812
- Windows 11 Pro
A new scene, same problem. I did a material override, so it isn't a material.
https://drive.google.com/file/d/1wlG...usp=share_linkBobby Parker
phone: 2188206812
- Windows 11 Pro
It is disabled when viewing the composite modeLast edited by fixeighted; 21-10-2023, 11:51 PM.
Can you elaborate?Bobby Parker
phone: 2188206812
- Windows 11 Pro
Well, that is a bug! Thank you!Bobby Parker
phone: 2188206812
- Windows 11 Pro
No problem. Don't know if it's a bug per se, as of course the light cache is in fact calculated, but certainly it's something that can cause confusion, as it's not obvious at first glance
I don't know if it's mentioned anywhere in the docs but probably should be noted there to save others' headaches
- Likes 1
Originally posted by glorybound View PostWell, that is a bug! Thank you!
