Has something broke over the past two updates? I can no longer zoom or use focal length. Film gate seems to work. When using zoom or focal length, I can see the camera geometry move in the scene, but the view port doesn't change.
V-Ray Camera
V-Ray Camera
Bobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090 X2
- Windows 11 Pro
Tags: None
I'm on 2020 and vray 6.1 (whatever the latest is) and fov works as expected but zoom doesn't work in real-time. I can change the value but the view doesn't change until I deselect and reselect the camera.www.dpict3d.com - "That's a very nice rendering, Dave. I think you've improved a great deal." - HAL9000... At least I have one fan.
- Likes 1
Hi, thank you for reporting the issue. I tracked it far back. This behavior hasn't changed because of the last 2 updates. Furthermore, the same behavior could be seen with Max's Physical camera rendered on Scanline. The issue is reported to our devs under VMAX-13220.
Meanwhile, you could use Focal length, with which the Zoom factor works fine.
Still wondering who on earth is using FOV? Also, why is this the default?
https://forums.chaos.com/forum/v-ray...-field-of-view
