Chaos Scatter - moving the surfaces and spline areas is extremely slow and takes 100% CPU resources
  • Chaos Scatter - moving the surfaces and spline areas is extremely slow and takes 100% CPU resources
    I've noticed for a while that moving around Chaos Scatter surfaces and spline areas is extremely slow (FPS drops to ~10). Moreover, doing this takes 100% CPU resources and my CPU cooler revs up instantly as if it's starting to overheat (temps also spike to 80-90*C instantly). Is this normal and can it be alleviated? This happens even with the simples scatters when the display mode is set to "Wire box" and ~5000 total displayed instances in the viewport. Forest Pack doesn't have these issues. Everything is extremely fluid when moving the surfaces/splines around and the CPU usage when doing so is ~15% with my fans not spinning at all.
    Is it possible for the instances' positions to not change when I move the surface or the area splines? This is an issue when I have to adjust a surface or an area spline and then I have to do a region render. With Forest Pack the instances stay where they are no matter where I move the surface or the area spline.
    Aleksandar Mitov
    www.renarvisuals.com
    office@renarvisuals.com
    AMD Ryzen 9 9950X 16-core
    96GB DDR5
    Hi, Alex_M. Could you please provide the scene described in your post? It will help us to understand the problem better. You could send it through our support form. Please add a link of this thread in your ticket.
